i have 1 MV bluray, it is not split to multiple small, so how to mux video with chapters
Code:General ID : 0 (0x0) Complete name : E:\BDMV\STREAM\00002.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 35.9 GiB Duration : 3 h 13 min Overall bit rate mode : Variable Overall bit rate : 26.6 Mb/s Maximum Overall bit rate : 48.0 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 3 h 13 min Bit rate mode : Variable Bit rate : 23.2 Mb/s Maximum bit rate : 35.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 (30000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.373 Stream size : 31.4 GiB (87%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : PCM Format settings : Big / Signed Muxing mode : Blu-ray Codec ID : 128 Duration : 3 h 13 min Bit rate mode : Constant Bit rate : 2 304 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 3.12 GiB (9%)Code:CHAPTER01=00:00:00.000 CHAPTER01NAME= CHAPTER02=00:06:02.929 CHAPTER02NAME= CHAPTER03=00:11:22.282 CHAPTER03NAME= CHAPTER04=00:18:32.612 CHAPTER04NAME= CHAPTER05=00:20:16.282 CHAPTER05NAME= CHAPTER06=00:25:57.923 CHAPTER06NAME= CHAPTER07=00:27:53.739 CHAPTER07NAME= CHAPTER08=00:32:40.759 CHAPTER08NAME= CHAPTER09=00:33:31.510 CHAPTER09NAME= CHAPTER10=00:38:22.233 CHAPTER10NAME= CHAPTER11=00:39:56.394 CHAPTER11NAME= CHAPTER12=00:45:15.780 CHAPTER12NAME= CHAPTER13=00:46:07.265 CHAPTER13NAME= CHAPTER14=00:50:32.396 CHAPTER14NAME= CHAPTER15=00:52:10.194 CHAPTER15NAME= CHAPTER16=00:57:40.424 CHAPTER16NAME= CHAPTER17=00:59:17.387 CHAPTER17NAME= CHAPTER18=01:04:19.389 CHAPTER18NAME= CHAPTER19=01:04:47.183 CHAPTER19NAME= CHAPTER20=01:09:08.011 CHAPTER20NAME= CHAPTER21=01:10:12.775 CHAPTER21NAME= CHAPTER22=01:42:03.818 CHAPTER22NAME= CHAPTER23=01:43:57.765 CHAPTER23NAME= CHAPTER24=01:49:01.168 CHAPTER24NAME= CHAPTER25=01:51:10.464 CHAPTER25NAME= CHAPTER26=01:59:38.672 CHAPTER26NAME= CHAPTER27=02:00:43.870 CHAPTER27NAME= CHAPTER28=02:05:53.179 CHAPTER28NAME= CHAPTER29=02:07:09.755 CHAPTER29NAME= CHAPTER30=02:17:47.593 CHAPTER30NAME= CHAPTER31=02:18:25.130 CHAPTER31NAME= CHAPTER32=02:23:04.843 CHAPTER32NAME= CHAPTER33=02:24:08.206 CHAPTER33NAME= CHAPTER34=02:28:37.075 CHAPTER34NAME= CHAPTER35=02:29:00.999 CHAPTER35NAME= CHAPTER36=02:33:39.510 CHAPTER36NAME= CHAPTER37=02:34:16.948 CHAPTER37NAME= CHAPTER38=02:39:39.470 CHAPTER38NAME= CHAPTER39=02:41:15.466 CHAPTER39NAME= CHAPTER40=02:45:48.071 CHAPTER40NAME= CHAPTER41=02:46:52.970 CHAPTER41NAME= CHAPTER42=02:51:30.113 CHAPTER42NAME= CHAPTER43=02:52:35.745 CHAPTER43NAME= CHAPTER44=02:57:47.090 CHAPTER44NAME= CHAPTER45=03:06:14.597 CHAPTER45NAME=
ismdownloader failed to mux files - how to mux them?
By renesti in forum Video Streaming DownloadingReplies: 2Last Post: 31st Mar 2018, 10:36 -
how can i mux cc with video and audio?
By tianhanghai in forum SubtitleReplies: 0Last Post: 28th Feb 2018, 22:13 -
[help] pls introduce some best video MUX tools to me. (not re-encode video)
By truston in forum Video ConversionReplies: 4Last Post: 11th Mar 2017, 07:22 -
Mux video and audio without losing the video ig track?
By Oakeyt in forum Authoring (Blu-ray)Replies: 2Last Post: 22nd Feb 2016, 04:29 -
Stretch, Sync and Mux audio to video
By xtrips in forum AudioReplies: 5Last Post: 20th May 2015, 15:48
